AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Amana Gas dryer high pitched squeel when running
9yo Amana Commercial Gas dryer has a high-pitched squeel - seems to get a little louder the longer dryer runs/heats up. It is louder outside house than inside. Neighbor says sounds like an airplane engine - kinda does. What is it likely to be? Have not taken it apart yet - looks like the entire case has to be lifted off to get to anything, so have to put on its side. Would that be okay for the unit? It still dries great.
I had the same problem, now my dryer stopped working, can't figure out how to get the back panel off to get to the parts
Originally Posted by: fixorbuy  9yo Amana Commercial Gas dryer has a high-pitched squeel - seems to get a little louder the longer dryer runs/heats up. It is louder outside house than inside. Neighbor says sounds like an airplane engine - kinda does. What is it likely to be? Have not taken it apart yet - looks like the entire case has to be lifted off to get to anything, so have to put on its side. Would that be okay for the unit? It still dries great. The model number you posted does not come up. Verify and repost it please. Gene.
Originally Posted by: mary'sdryer  I had the same problem, now my dryer stopped working, can't figure out how to get the back panel off to get to the parts What is the complete model number of the dryer? Gene.
Dryer Model Number is: LGA30AW or PLGA30AW Amana "Commercial Quality" Gas dryer. Trying to decide if I should try to have it fixed, or buy a new one. Would appreciate your feedback.
Originally Posted by: fixorbuy  Dryer Model Number is: LGA30AW or PLGA30AW Amana "Commercial Quality" Gas dryer. Trying to decide if I should try to have it fixed, or buy a new one. Would appreciate your feedback. Take the dryer apart and check the glides and pads (#13 & #14 on the diagram). Also check the drum support rollers (#16 on the diagram) and the idler pulley (#19 on the diagram). Here is the Service manual. - The glide (2 needed) Part number: AP4046795
Thank you so much for all the info..incl the Service Manual! Tried to find that at Amana website before contacting you and its not there. Will proceed with your suggestions!
Hi...should I replace the drive belt when replacing the other items you have suggested?
Thanks,
Mark
Originally Posted by: mwipper  Hi...should I replace the drive belt when replacing the other items you have suggested?
Thanks,
Mark Mark, Only if it is worn out. Gene.
Dryer Repair
