mcflash
#1 Posted : Monday, June 30, 2008 11:57:56 AM(UTC)
mcflash
Washer will fill and drain but will not agitate or spin. Makes a grinding spinning noise with the motor when the lid is closed.:mad:
kfowkes5
#2 Posted : Monday, June 30, 2008 2:37:34 PM(UTC)
kfowkes5
Mine is doing the same thing! I hope we can get an answer soon!
mcflash
#3 Posted : Monday, June 30, 2008 6:27:55 PM(UTC)
mcflash
It was the coupler fitting that is between the motor and the transmission. Took the repair man 15 min to fix at $90.00 total. If you have it repaired make sure that he installs the new upgraded fitting with the metal ring to help to keep the gear from splitting in the future. My repairman the new part just came out about 6 weeks ago.
Good luck!!
