Peter Zantingh
#1 Posted : Thursday, August 19, 2010 10:43:26 AM(UTC)
Peter Zantingh
water won't stop running. i replaced the pressure valve and the timer. Would it be the water dispenser valve
Joe / APP Team
#2 Posted : Thursday, August 19, 2010 10:58:01 AM(UTC)
Joe / APP Team
Peter,
It could very well be the fill valve.
Does the water stop, if you turn the machine off ?
If the answer is yes, then it would be a bad water level tube(air dome hose)that attaches to the water level (pressure) switch.
If you have to turn the faucet off, to stop the water going into the machine, then you definitely have a bad water inlet fill valve.
Hope this helps.
:cool: :cool: :cool:
