john@kimandassociates.com
#1 Posted : Thursday, August 19, 2010 8:18:42 AM(UTC)
part# ap2033180
inner panel paint has been deroded & coming out, do i replace the inner panel or whole door & how do i replace it??
#2 Posted : Thursday, August 19, 2010 11:14:32 AM(UTC)
John,
GE does not sell separate door parts for this model, so your choice is the whole door assembly only.
You have to remove the microwave from the cabinet. Remove the outer case and the upper door hinge. After you install the new door make sure the door switches (## 1445, 1446 & 1447 on the diagram) are properly engaged when the door is closed and the door is aligned properly.
The door assembly Part number: AP2033180
