keelo
#1 Posted : Monday, June 30, 2008 12:52:05 PM(UTC)
keelo
I am contemplating replacing an errant spark igniter on my GE JGP336 gas range.
I have been unable to find an exploded view to determine if I can attack this problem from the top by 'slowing' pulling out the old electrode -or- will I have to flip the range and disassemble it to remove a holding clip.
Just trying to determine how I should approach it.
Regards,
abadfish66
#2 Posted : Monday, June 30, 2008 12:54:43 PM(UTC)
abadfish66
It pulls up, use some pliers and wiggle as you pull upward.
abadfish66
#3 Posted : Monday, June 30, 2008 12:55:52 PM(UTC)
abadfish66
FYI do not unscrew anything from the bottom, everything is done from the top. What is your cooktop doing?
keelo
#4 Posted : Monday, June 30, 2008 1:45:52 PM(UTC)
keelo
Fixed it, thanks, though I did have to remove the top to reinstall the holding bracket.
My wife didn't realize there was a slot for the ignitor, so when she "banged" it back into position, it physically broke something within the electrode.
This place is invaluable - thanks for the help.
skassamali
#5 Posted : Thursday, December 31, 2009 7:48:56 AM(UTC)
skassamali
Mine turned out to be a bad spark module.
