Lisatt
#1 Posted : Sunday, June 29, 2008 9:43:08 PM(UTC)
Lisatt
Dishwasher has no power. Breakers are fine. It just won't start. Is there any way to reset.:confused:
#2 Posted : Monday, June 30, 2008 1:56:46 PM(UTC)
Check for 120VAC at the power outlet for the dishwasher. Remove the bottom panel and check wires in the junction box under the dishwasher.
If there is nothing wrong then call Bosch for service under the manufacturer warranty due to it's less than a year old.
P.S. The model number you posted does not come up.
Lisatt
#3 Posted : Wednesday, July 2, 2008 9:35:45 AM(UTC)
Lisatt
Did all that.....still no power. Model number on invoice says SHE44C05UC. Is it different in Canada?
I have called for service
Thank you for your help
redicrandle@yahoo.com
#4 Posted : Tuesday, February 15, 2011 8:29:55 AM(UTC)
Hi Again Friends,
The Model # is as follows: SDF7811ST and the s/n # is as follows: 503kw-01461. This unit was made be a company called LG Electronics.
Now, I have already replaced the main board and the power board which was badly burned. However, the unit still does not power up. I at a loss for what could be wrong now. I was wondering if this unit has a thermal fuse or something? Is there something else that I can do? Thank you.
Randy
#5 Posted : Tuesday, February 15, 2011 8:42:11 AM(UTC)
Hello!
Is anybody there? I am new to this kind of communication. Please help me if you can. Thank you.
Randy
#6 Posted : Tuesday, February 15, 2011 9:19:25 AM(UTC)
Hi Friend,
Regarding resetting of this dishwasher unit, I cannot see any breaker or any other type of switch that would allow me to reset the power. As far as I can see, it's just hard wired into the system.
Kitchen Aid Electric Rang Power Problem (Oven Repair (including Ranges and Cooktops))
by Guest 3/10/2024 7:24:24 PM(UTC)
Kenmore Pro-power problem??? (Refrigerator & Freezer Repair)
by msbee03 7/28/2011 4:09:39 AM(UTC)
Dishwasher Power Problem (Dishwasher Repair)
by redicrandle@yahoo.com 2/15/2011 8:10:07 AM(UTC)
Kenmore Oasis 27032600 Power Problem (Washer Repair)
by nylabor 10/31/2009 1:58:01 PM(UTC)
Matag power problem (Washer Repair)
by Baileyr 10/3/2009 7:03:56 PM(UTC)
Nothing Operating after Power Problem (Microwave Repair)
by bigburn64 5/20/2008 8:51:40 PM(UTC)
