Here is your tech sheet
http://www.servicematters.com/d...0Sheet%20-%202311817.pdf[COLOR="Blue"]I opened the cover on the freezer side and the evaporator had heavy frost and ice build up.[/COLOR]
Yes this does sound like a defrost problem.
The coils have to be iced/frosted up to the point where the evaporator fan cannot pull air through them.
The board you ordered could be the problem but it could also be the heater or the defrost thermostat.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle (see the tech sheet) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the board you ordered should fix the problem
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 25 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost board is toast as it is not automatically doing a defrost cycle.
