g_farler
#1 Posted : Sunday, June 15, 2008 10:02:12 AM(UTC)
g_farler
i have a kitchenaid kucc151vo compactor. turning the switch with rocker switch in normal position it works fine.putting the rocker switch on solid position it trys to work for a second. returning switch to normal it runs back up. do you think i have a bad rocker switch. air filter switch is same type of switch and same part #. thinking about switching wires around and checking that way. what do you think. garth:(
MCHILT
#2 Posted : Sunday, June 29, 2008 7:35:10 AM(UTC)
MCHILT
I am experience same issue with Kitchenaid KUCS02CRSS1. Works fine on normal mode, does not work on solid mode.
Did you ever find a solution?
Thanks.
g_farler
#3 Posted : Sunday, June 29, 2008 8:20:24 AM(UTC)
g_farler
yes. i ,used the fan switch,which is next to it and switched wire's as a test and it worked. on my unit they are the same part number. if you have a fan switch, you may want to try it.
