None of the four burners on my GE Profile range will ignite. They work fine when lit by an external flame so they are receiving gas. Saw both ignitors and spark modules on your web site and wasn't sure which one would be the right replacement.
Does any of the burners click and/or spark when any of the knobs turned ON?
No clicks or sparks from any of them, all you hear is gas.
Most likely the problem is a bad spark module, but there is a small chance for the ignition switch harness to be bad as well. I would order and replace both of them (they are not expensive). If one of them is still good you can return it later. - The spark module Part number: AP3778816
