When dryer is started, igniter glows and gas ignites normally. After a while flame goes out, presumably because correct temperature has been reached and thermostat kicks in. Problem is that after this, the igniter will glow but gas doesn't ignite. I'm guessing solenoid and/or coil problems. Please help.
