#1 Posted : Saturday, August 14, 2010 7:08:57 AM(UTC)
Damper door was closed, no air getting into the fridg. section. Unplugged fridg. and found damper door open.
Put everything back together, plugged it in, now damper door is open.
Hope someone has seen this before, maybe a bad connection on the damper motor, a computer re-set, or just stuck damper door.
Hope someone has seen this before. Thanks in advance.
#2 Posted : Saturday, August 14, 2010 8:36:59 AM(UTC)
In retrospect,I think it was a bad connection or a stuck control, will check later.
