parisg
#1 Posted : Monday, June 23, 2008 8:34:28 AM(UTC)
parisg
I am having a problem with my Kenmore dryer, model 110.63102101 shutting off after about 20 minutes of drying time. It started about 3 weeks ago. I took the back off, cleaned it all out, cleaned the lint duct, whatever I could reach. It ran fine for a couple of weeks, but now the problem is back. From a cold start, it will run normal for about 20 minutes, then shut down. Restarting it after about a half hour, it will run for about 5 minutes. If I immediately restart it, it may run for less than a minute, or not start at all. If I come back after a while, it will restart, but run only for a short time. Something inside needs to cool down first.
This condition is in high heat, and low heat is not much better. I can run a normal cycle in air dry.
Any suggestions?
kayakcrzy
#2 Posted : Thursday, June 26, 2008 4:40:01 AM(UTC)
kayakcrzy
You have a motor problem, and need to replace it. It is overheating and cutting off. Tom ApplianceEducator.com
Kenmore Dryer Shuts off prematurely (Dryer Repair)
by mreddy 6/25/2009 1:30:40 PM(UTC)
Kenmore dryer shuts off (Dryer Repair)
by dpswitched 12/26/2007 9:40:26 PM(UTC)
