I'll see if I can find a wiring diagram, but it's pretty safe to assume that you will need a new main board to fix the problem
Which main board are you referring to? Where is it mounted? I replaced the board mounted behind the controls for ice dispensing (on the freezer door). If you could come up with the wiring diagram, I'd be able to trace it myself. Thanks for all your help. Let me know either way. Best regards, Bob
The main board on the back of the unit. What is your e-mail, I'll send the schematic to you.
