Some of the touch pad control buttons (bake, oven light )and the number 7,9 are not working. Which part I need to replace for this problm? -touch pad or Electronic clock control
Originally Posted by: jakyl07  Some of the touch pad control buttons (bake, oven light )and the number 7,9 are not working. Which part I need to replace for this problm? -touch pad or Electronic clock control You may want to attempt to clean the contacts on the control board and end of the touchpad ribbon, with alcohol or a non residue contact cleaner. If that doesn't work, replace the control panel assembly. (click on part number) Part number: AP4425938
