jeab
#1 Posted : Tuesday, August 10, 2010 11:46:30 AM(UTC)
jeab
After a power surge the Dacor oven will not heat to temperature.
The oven button is selected then the temperature increase button is selected which shows the standard 350 degrees, after a minute it then reads pre-heat at 135 but does not heat up. Also it will not heat up on broil or convection. I turned the electric breaker off-on as well as depressing the high temperature relay reset behind the door latch without any success.
Any suggestions.
Wayne
vdannie
#2 Posted : Thursday, September 1, 2011 5:20:23 AM(UTC)
vdannie
Wayne, I'm having the same issue, did you find a solution?
Vic
Guest (4)
