after defrosting the refrigerator ICE MAKER is making ice only for one time ice maker led light stays solid green dual solanoide works fine water line to ice maker has no ice will somebody help on this issue? thanks in advance
Turn the ice maker "off" for a minute. Turn it "on" and during the first 15 seconds push the feeler arm from the 'out' position to the "in" position and back again 3 times (3 times only) to enter the service diagnostic mode. It consists of a harvest cycle followed by a water fill (5.1 sec).
Post the results.
Gene, Thanks For Your Reply I Did What You Said To Do After I Pushed The Arm For 3 Times Ice Made For One Time And Then After Green Light Steady On But No More Ice Will You Help Me For This?
Looks like the problem is a bad control board in the ice maker. GE recently introduced newly designed ice maker due to many problems with the one in your fridge. - The part number for the ice maker is AP4345120 Gene.
Gene sorry for late reply I was out on business tour for 3 days is this part is GE Refrigerator Ice Maker IM6 Kit ? or GE Ice Maker WR30X10061 please suggest which one to buy? let me know so i can buy thepart how much time it will take to chane the ice maker? will you give me your expert tips on changing this? thanks Raj
Gene is correct, The new icemaker is an electromechanical design, way better than the electronic model. The guts of the icemaker is made up of the same components as the old one that worked with the arm that lifted up..
abadfish66 and Gene:confused:
will be give me the icemaker model no ? which I mentioned in my previous post? Gene gave the part no buton website no photo of product so I want to confirm first that I am buying GE Ice Maker WR30X10061
Actually the new part# is WR30x10093, it should take you about 5 minutes to change it, just remove the 2 screws and unplug the wire plug. You do need to transfer to the new icemaker the fill tray and shield, you'll see what I'm talking about when you get the new icemaker
abadfish66 thanks for your help I put the new ice maker and working fine any recall on this model or not? will you help me on this ?
No recall on your model. An icemaker is considered an accessory, it can and probably will fail before the expected lifespan of the refrigerator. Glad you were able to fix the problem.
