AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Maytag washer will not agitate/cold water fill won't shut off
Maytag washer first problem cold water would not stop filling, even when machine shut off. Have to close cold water spigot to stop. This happened for a week or so. Then last wash cycle, washer would not agitate on either wash or rinse cycle. This is the case for all settings ( regular, perm press, delicate). Washer will fill, and will spin. Have made certain that drum is not off balance; have tried with washer full and empty.
The first thing you may want to do is replace the water inlet valve (#8 on the diagram). It should fix the first problem and might help to eliminate the second problem too. - The water inlet valve Part number: AP4026239
thanks, I will try that! the agitator is working at present; just a one time thing, and may have been related to my playing with the water level in an attempt to cut off the water....:)
Hi Gene, this is Tom, who is trying to fix the washer for Denise. thanks for the advice. I took the inlet valve apart and noticed that all the little pores in a circle around the cold water inlet valve were not venting. massaged them with vinegar until clean, reassembled and now the valve works fine.
the remaining issue is that the motor will run in spin mode just fine, but only hums feebly in agitate mode and does not rotate. I cleaned and filed all the contacts in the centrifugal switch (which now appears to be working correctly) and the motor does not appear to have any burnt coils, so I am currently guessing that there are just cruddy contacts in the timer. any more ideas that you may have are appreciated greatly.
Hi Tom,
You can remove the cover from the timer and visually inspect all contacts.
Hi gene,
removed cover, filed and resprung contacts and Mr. Washer is washing like new. Thanks for taking time to help!
Tom
You are welcome Tom. I'm glad you were able to fix it with no cost to you. Good job!
Could this be caused by gunk in the water supply plugging the water control valve as discussed above?
Yes, it could. If the water inlet itself is clogged, then it's better to replace it. Cleaning would not make it reliable.
Washer Repair
