Robgw007
#1 Posted : Thursday, August 5, 2010 10:46:59 AM(UTC)
Robgw007
I've replaced the heating element, thermostats, and main control board twice. checked and got 240v at heating relay (RL2). diagnostics packet says thats a bad relay, but twice? could it be that I have the wrong part from this site? Part numbers on the back are different but just thought maybe its the age that changed it and it looks exactly the same. Voltage ratings on relay and set up looks the same. I'm scratching my head and would really like a dryer. I hope if your reading this your smarter then me and have some advice!
#2 Posted : Saturday, August 7, 2010 3:36:28 AM(UTC)
Replacement parts for FRIGIDAIRE FEFB9200ES0 Frigidaire/dryer | AppliancePartsPros.com
Here is a tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134509400efsa.pdf
Try running the diagnostics.
"diagnostics packet says thats a bad relay, but twice?"
I agree with you, having a bad relay on two new boards is very unlikely.
Check the thermistor resistance.
Be sure to remove at least one side of any device you check for resistance.
This prevents you from reading an alternate/parallel circuit path.
#3 Posted : Saturday, August 7, 2010 7:59:40 AM(UTC)
Your data sheet should show the thermistor resistance value, common for these to get damaged, AP3866842
#4 Posted : Saturday, August 7, 2010 8:04:44 AM(UTC)
Robgw007
#5 Posted : Saturday, August 7, 2010 10:15:24 PM(UTC)
Robgw007
I checked the resistance and only got 3K when I was supposed to get 50K. Thank you very much for the response I think you just fixed my dryer. I didn't even see that little guy berried under the drum. So you are smarter then me. thanks again.
Guest (5)
