ckostelec
#1 Posted : Tuesday, August 3, 2010 1:52:33 PM(UTC)
ckostelec
My Bosch SHU9915UC U11 has stopped cleaning well. Also it is so noisey I know something is going on. Replacing the pump sounds easy enough but how do you get the Bosch screws off the panel below? I would think its the pump but I'm a teacher and have no experience with these things. Thanks.
#2 Posted : Tuesday, August 3, 2010 4:13:44 PM(UTC)
Before you do any repairs, remove the screens inside the dishwasher and clean all debris inside. Follow the instructions in the Owner manual.
ckostelec
#3 Posted : Tuesday, August 3, 2010 6:03:40 PM(UTC)
ckostelec
I have done that so many times. There is water that pools in the bottom under the ring tower. Help!! Again thanks for any input
Catherine
#4 Posted : Tuesday, August 3, 2010 6:24:01 PM(UTC)
Catherine,
I feel there are a pieces of broken glass, causing that noise. I attached some instructions to the reply.
File Attachment(s):
Care and Cleaning.doc (280kb) downloaded 24 time(s).
