scblair
#1 Posted : 15 years ago
scblair
My electric oven operates correctly when you enter a bake mode and temp. So if I enter bake and then 375, all's good. But a little later if I try to change the temp (say bake/425) it accepts the input and seems OK but the oven temp does not change. Also, if I cancel (shut-off) the oven and try to restart the oven (at say 425) again there is no heating. It acts like it is already at temp except that there is no "ding" indicating it has reached it. Feels like a control board.
Any experence w/ this issue?
#2 Posted : 15 years ago
Originally Posted by: scblair Go to Quoted Post
...Feels like a control board...
Looks like you are right and the problem is a bad ERC. While replacing the ERC you can use the attached Service bulletin as the instructions.
- The ERC Part number: AP4325114
File Attachment(s):
scblair
#3 Posted : 15 years ago
scblair
Thank you very much! Is this part the same for all the ER models? Mine is the ER36DSCH w/ electric oven.
#4 Posted : 15 years ago
You are welcome. This part is good for all ER36xxxx models.
scblair
#5 Posted : 15 years ago
scblair
Sweet - can't wait to get on it. This Dacor unit has had its share of problems but it is hell when its well so I'm just gonna have to add range mechanic to my skill set! Have you read the bulletin? Hard to understand the wiring harness mods but maybe it will be easier to understand when I see it.
Thanks again, will place the order soon.
-pat
scblair
#6 Posted : 15 years ago
scblair
Gene, I received the control unit and it did not come with a harness. In regard to the service bulletin you posted, does this mean I will have a straight swap out with no harness mods?
Thanks!
-pat
#7 Posted : 15 years ago
The new control unit should not have any harness included. The Bulletin says to remove the harness adapter if it was used. It also says that it was not used on all units.
You'll see it only after you disassembled the unit.
scblair
#8 Posted : 15 years ago
scblair
I was lucky and had a straight swap out - thanks Gene! And it's all working great again.
-pat
#9 Posted : 15 years ago
You are welcome Pat. I'm glad you were able to fix it.
