AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Frige runs all the time but is cold and water coming out of the freezer
I've just started having a problem with my fridge. It's been running without stopping and water has started coming out of the freezer. It collects in the bottom and freezes there but overflows out the bottem. It still keeps the food cold and the freezer still keeps the food frozen. I have noticed moisture condensation in the fridge also. What can I do?
Looks like there are two problems. Clogged and/or frozen drain under the evaporator in the freezer and possible improper auto defrost. It might also needs the condenser cleaning.
Thanks for the help, Gene. I can't seem to find that panel in the back of my freezer. I have and automatic ice maker/water dispenser in that spot.:)
Originally Posted by: Olady Thanks for the help, Gene. I can't seem to find that panel in the back of my freezer. I have and automatic ice maker/water dispenser in that spot.:) What is the complete model number of the refrigerator? Gene.
The model number is HMG2190-2 It's a Montgomery Wards fridge.
Unfortunately this model number does not come up. Probably due to its age.
The panel in the freezer which has to be removed is actually the very rear panel. Possible the ice maker has to be removed first. If you can post a picture of the freezer, it might help.
