Cleaned the oven, self cleaning. Now setting the oven control to any other setting, Broil or a tempurature setting, the clean light flashes. Clean still works, nothing else works.:confused: any ideas?
Originally Posted by: lildiesel59 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Cleaned the oven, self cleaning. Now setting the oven control to any other setting, Broil or a tempurature setting, the clean light flashes. Clean still works, nothing else works.:confused: any ideas? Got the model number RGB746HED3WH
Most likely your problem is with one of the lock switches, go ahaed and lock and unlock the door a couple of times to see if tht helps. Alot of times mice will take dog or cat food up the oven, and the food will deteriate the switches, and or wires.
