2 Pages12>
Bumkus
#1 Posted : Tuesday, June 17, 2008 7:46:13 PM(UTC)
Bumkus
I can not start a new wash cycle.The dishwasher finished its wash cycle and the clean light is lit up but when trying to start a new wash cycle it lights the cycle light but when you push the start button it goes back to the clean light button. If i push cancel and drain it will, but can not start a new wash cycle.
#2 Posted : Wednesday, June 18, 2008 6:29:52 PM(UTC)
Does the "clean" light stays solid or it's blinking?
If it stays solid, would it go "off" if you open and close the door?
Try to unplug the power cord (under the sink) for a few minutes. Sometime it helps to eliminate a problem.
Bumkus
#3 Posted : Thursday, June 19, 2008 5:11:21 PM(UTC)
Bumkus
clean light is blinking. I tried opening and closing the door and also killed the power to it but it didn't change anything.
#4 Posted : Thursday, June 19, 2008 5:25:36 PM(UTC)
The clean light blinking seven times in a row means the control senses a problem with the heat circuit. Look into the complete manufacturer instructions to solve the problem.
Here are the tech sheets for your dishwasher.
Bumkus
#5 Posted : Friday, June 20, 2008 6:57:20 PM(UTC)
Bumkus
Thanks Gene for the info. I almost went and bought a new board. So far everything seems to be working fine. I know after three cycles it should detect a problem but so far so good.
makusmi
#6 Posted : Saturday, May 21, 2011 3:40:18 AM(UTC)
makusmi
my diswasher has similar aissue to what is discussed in this message, the clean light is stuck on and when pressing the start / cancel nutton nothing happens. I tripped the breaker in hopes to reset and all 3 lights were blinking, it would start a new wash cycle but had very little water pressure and the motor sounded like it was running at 50%? It was also ver noisey, any ideas?
#7 Posted : Saturday, May 21, 2011 1:14:55 PM(UTC)
What is the complete model number of the dishwasher?
Is the Clean light blinking or it's steady On?
makusmi
#8 Posted : Saturday, May 21, 2011 1:21:36 PM(UTC)
makusmi
Gene thanks for responding. I am not home now to get exact model number but will send this evening. In the mean time I reset the breaker again and ran the washer through complete cycle°c and it seemed good? However when I went to run again the clean let light is on solid green and it won't start again same problem. I did not try the breaker yet but sure it will work .
#9 Posted : Saturday, May 21, 2011 1:29:10 PM(UTC)
There is not much what I can do without the model number.
makusmi
#10 Posted : Sunday, May 22, 2011 5:16:37 AM(UTC)
makusmi
the model number is FDB1050REC0
Thx
Guest (10)
2 Pages12>
