FixingIt
#1 Posted : Wednesday, June 18, 2008 2:42:07 PM(UTC)
FixingIt
I have a Frigidaire dishwasher that will fill with water and run through the cycles, but it does not clean the dishes. I listened to it run and I do not believe the sprayers are turning. Is this the motor or the sprayer?
FixingIt
#2 Posted : Wednesday, June 18, 2008 5:16:47 PM(UTC)
FixingIt
It is definitely that the sprayer is not turning. Water is coming up through the sprayer, but it does not turn. Motor or just a part of the turning mechanisim?
#3 Posted : Thursday, June 19, 2008 4:49:51 PM(UTC)
It could be not enough water or a problem with the wash pump.
FixingIt
#4 Posted : Saturday, June 21, 2008 9:56:29 AM(UTC)
FixingIt
Do you think it is the pump or the inlet water valve?
#5 Posted : Sunday, June 22, 2008 12:04:45 PM(UTC)
It has to be tested. Guessing is most expensive way to fix appliances.
#6 Posted : Monday, June 23, 2008 2:34:13 AM(UTC)
Dump a few gallons of water in the dishwasher and see if it now works, if so, you might have a partially clogged screen in the water solenoid.
If still not ok, remove the pump cover and check for something blocking the pump.
