Craig S.
#1 Posted : Thursday, June 19, 2008 12:56:19 PM(UTC)
Craig S.
I have a Frigidaire Refrigerator with the Freezer compartment on top. We bought it brand new at Lowes about 5 years ago and has run fine since we have had it. I opened the freezer the other day and everything was melting. It was not producing any cold air in the freezer or the refrigerator. I turned the temperature control setting in each compartment up one notch in the colder direction. After a while it started getting colder. It reached normal operating temperature and lasted about two days. Now it is doing the same thing, it is not cooling anymore. Any suggestions?
#2 Posted : Friday, June 20, 2008 10:55:26 AM(UTC)
Hi Craig,
Remove the rear cover, clean the condenser coil (#1 on the system break down diagram) and check if the fan next to the condenser is running. This fan must run together with the compressor.
Post your findings.
