its gives a blinking code f and h then the washer stops working
Was there water in the washer or not?
What is the complete model number of the washer?
sometimes theres water ,modle number ghw9150pw0
The "FH" error code means "No water detected entering machine or pressure switch trip not detected". You have to perform the troubleshooting recommended by the manufacturer in the tech sheet. Gene.
Originally Posted by: Gene  The "FH" error code means "No water detected entering machine or pressure switch trip not detected". You have to perform the troubleshooting recommended by the manufacturer in the tech sheet. Gene. HOW DO I GET A TECH SHEET TELL ME PLEASE.....................
Please click on the "tech sheet" in the previous reply.
Thank You I Will Look At It.........
