AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
how do I replace water line in freezer door of whirlpool side by side
If you can not access it this way, then the only choice is to remove the inner door panel.
Originally Posted by: Gene  If you can not access it this way, then the only choice is to remove the inner door panel.
Gene. Is that the entire top to bottom panel with the shelves and all, held in place by all those hex screws hiding under the "gasket" or "pad" around the door? Is that like rebuilding an engine? Do you run the risk of not getting it back together again properly if you do so? Is there a high screw up factor involved? Is there a way to come in from the front?
Originally Posted by: cybolt  Is that the entire top to bottom panel with the shelves and all, held in place by all those hex screws hiding under the "gasket" or "pad" around the door?
Is there a way to come in from the front? Yes, it is the whole panel (#19 on the diagram). It is not a simple job, but there is no any other way. Gene.
Originally Posted by: Gene  Yes, it is the whole panel (#19 on the diagram). It is not a simple job, but there is no any other way. Gene. So seriously... is there a high screw up factor? Does one risk not getting it back together OK or is it simply removing all the screws, replacing the tube and putting it back together? I'm OK in these situations... not a mechanic but can figure stuff out OK. BTW, lovely day in SoCal, isnt it? I'm out in Upland, at the foot of Mt Baldy.
Originally Posted by: cybolt  So seriously... is there a high screw up factor? Does one risk not getting it back together OK or is it simply removing all the screws, replacing the tube and putting it back together?
BTW, lovely day in SoCal, isnt it? I'm out in Upland, at the foot of Mt Baldy. It is very nice, especially in Orange county. You have to remove the door from the fridge and put it on a flat surface to prevent it from twisting when you'll assemble it back. This is the most risky part of the job. Otherwise it's not going to be very difficult. Gene.
Gene. Many thanks! Have a great weekend!
You are welcome. Don't work too hard!:)
Groups:: Registered
I've got the same problem with a Whirlpool ED25CQXHW03. How do I replace the water line inside the freezer door to the dispenser?
DID ANYBODY EVER FIGURE OUT HOW TO SNAKE THE NEW TUBE BACK THROUGH THE DOOR OF THE FRIDGE? Erikda1 Originally Posted by: Gene
Originally Posted by: Erikda1  DID ANYBODY EVER FIGURE OUT HOW TO SNAKE THE NEW TUBE BACK THROUGH THE DOOR OF THE FRIDGE? Erikda1 What is the complete model number of the refrigerator? Gene.
