Hi, I just bought a new control panel from AppliancePartsPros which comes with the touch panel (key membrane) sealed into it.
My problem is that the ribbon cable that is supposed to plug into the power control module sub assembly (AP3034037) is different than the ribbon cable on my old control panel. The main difference is that there is one less conductor in the new cable. It is also narrower and the holes that are punched through it don't line up with the prongs in the blue plastic piece that is supposed to hold the cable in the socket.
So... can I still use this control panel somehow? Apparently the control panel module is not longer available, so I'm out of luck if I can't.
Thanks for the help!
What is the part number of the control panel you purchased?
AP3859379 (8205816) is what appears on my invoice. It looks nearly identical except there are a couple of new buttons.
Rank: Administration
Groups: Administrators
kvalentine, Lets start by getting your complete model and serial number off your microwave. I would like to first verify the part you received is correct. CLICK HERE FOR THEIR LOCATIONI will give you a call
