Hello, after a long break (for about 4 months) I used my dishwasher. The dishwasher made a horrible noise (nonstop cricket sound) the first few minutes, later the noise went away. Two hours later I found water coming out from underneath, so I took the panel out and found that water was leaking from the middle of the dishwasher. Called Frigidaire customer service and they told me that was the motor pump. I ran the dishwasher again in rinse cycle, it leak after the arms started to move and still leaking (4 hours later). Picture at Picasa Web Albums - Monica - Drop BoxWhat can I do to fix the problem?? Any ideas?
just wondering if you found a solution to this problem, we have the same thing going on... thanks!
No, I still looking for the solution, how about you?
