The whole thing unscrews.Counter clockwise
Took a bit of effort. Clogged with deposits from water. Thanks a million!
Lissa
The spray arm seems to have a LOT of calcium (?) deposits clogging the holes...what should I soak it in? Vinegar?
Originally Posted by: lissamarree  The spray arm seems to have a LOT of calcium (?) deposits clogging the holes...what should I soak it in? Vinegar? That works ok.I use Lime-A-Way or CLR.I also run 1 cup of Lime-A-Way in light wash cycle once a month to keep deposit away.Keeps the machine nice and clean.Glistens works good also. http://www.amazon.com/Harold-Im...y-Inc-9012/dp/B000GLRF2E
Originally Posted by: lissamarree  Took a bit of effort. Clogged with deposits from water. Thanks a million!
Lissa You're welcome
