Gene, I figured out the problem and the refrigerator is working fine. You can put this one in the boneheaded move category.
I use this refrigerator to keep kegs cold, so I have a piece of plywood in the bottom to make a level surface. I have had the plywood in there for several years without incident. After thinking about the return air path, I realized it must be under the plywood. So, I removed the plywood last night, and this morning the refrigerator is down to a frosty 35F.
I'm not sure what happened. I must have shifted the plywood just right so it blocked the return vents.
Anyway, thanks for the help. On the plus side, I now know how the temperature control system works in my refrigerator, so I should be able to figure it out with less effort in the future.
thanks again, Dave
You are welcome Dave. I'm glad you were able to solve the problem. Thank you for the feed back.
