repairneeded
#1 Posted : Thursday, July 29, 2010 1:58:37 PM(UTC)
repairneeded
I need help in knowing what to check on my gas dryer. It runs/sounds great on air fluff, but when using the heat cycles it makes a loud noise that seems to get worse the longer it runs. ANY HELP WOULD BE APPRECIATED..THANKS
#2 Posted : Thursday, July 29, 2010 4:09:56 PM(UTC)
You have to take the dryer apart and check the tumbler bearings (#30 on the diagram) and the rear drum support rollers (#24).
- The tumbler bearing kit (have to order two) Part number: AP4037304
- The drum support roller (have to order two) Part number: AP4008534
