used stuff user
#1 Posted : Wednesday, July 28, 2010 7:11:59 AM(UTC)
used stuff user
the used GE washer i bought yesterday makes a loud squeaking noise. on each revolution it make a very loud squeak one time per revolution. the guy i bought it from said it wasnt doing it when he used it last ...either he is lying or it coincidentally just happened. how do i fix it...im pretty sure it is quite level.
model GE Profile gdpsr473gv0ww
thanks,,,,,shaun:confused:
sidfink43
#2 Posted : Thursday, July 29, 2010 3:19:48 PM(UTC)
sidfink43
Your model number does not come up, but it is sorta traditional with GE dryers that the rear bearing goes bad, an easy and inexpensive repair.
Also, this does not just happen, so it probably was making some noise before you bought it, but see if you cannot fix it and all will be well.
used stuff user
#3 Posted : Thursday, July 29, 2010 3:27:45 PM(UTC)
used stuff user
i double checked the model number it isdpsr473gv0ww
where can i get the parts to fix it and how do ifix it. it works fine just squeaks on each revolution.
used stuff user
#4 Posted : Thursday, July 29, 2010 3:29:19 PM(UTC)
used stuff user
DPSR473GV0WWmodel
