The gas burners work okay. However, the digital pad has a message that reads 5 A6 and there is no response from any of the pads. I cannot set the clock or turn my oven on. We had a thunder storm recently and I wonder if it is a possibility that it was struck by lightning. The oven light works so I know there is electricity going to it. Please respond as soon as possible. Thanks. Annette Chaapel Delhi Iowa 52223
Originally Posted by: Annette Chaapel  The gas burners work okay. However, the digital pad has a message that reads 5 A6 and there is no response from any of the pads. I cannot set the clock or turn my oven on. We had a thunder storm recently and I wonder if it is a possibility that it was struck by lightning. The oven light works so I know there is electricity going to it. Please respond as soon as possible. Thanks. Annette Chaapel Delhi Iowa 52223 Your 5A6 code is actually SAB (sabboth mode). Press and hold the clock pad(button) for 5 seconds and clock should reset to time of day mode and control should operate.
