My dryer will not shut off, I have to leave the door open or it will restart on its own. The timer keeps going through the stop cycle and restarts on the time setting for each cycle. It's as if the push to start is permanently on.
Most likely the problem is a bad start switch. The model number you posted is incomplete or incorrect and I'm not able to provide more accurate advise.
