pasricat
#1 Posted : 15 years ago
pasricat
The microwave blower goes on and stays on, light does not turn off if the door is closed and microwave itself does not work (warming food). The blower turns off but the light stays on at all times if door is opened. I am able to enter the time but countdown does not start. Tried unplugging, but does not fix issue.
Pls Help
Joe / APP Team
#2 Posted : 15 years ago
Joe / APP Team
Pls Help
You could have a malfuntioning door latch assembly or catch, But most likely a bad door switch.
I don't reccomend you attempt to test or repair a door switch on a microwave due to the location of several high voltage components, and possible injury if you should come in contact with wires or components(even if the unit is unplugged).
You would not have a RF leak detector, you need to check for rf leakage whenever the door is serviced for safety sake.
