cmb78
#1 Posted : Monday, July 26, 2010 10:14:49 AM(UTC)
cmb78
My dishwasher was working fine and then this weekend I went to start a load and it will not advance on the dial. It just sits in the same spot. I can manually advance the dial and make it purge and fill at the start of the wash cycle but I cannot make it go through a wash cycle. It's like that doesn't exist anymore. We have had some bad storms recently, wondering if that has anything to do with it. Hoping to repair ourselves. Any ideas?
Thanks!:confused:
Joe / APP Team
#2 Posted : Monday, July 26, 2010 10:58:05 AM(UTC)
Joe / APP Team
Thanks!:confused:
Check the float and switch assembly(front left corner of tub assembly. Raise and lower float and listen for click noise. no click indicates a jammed float or bad water level switch, switch must close in order for timer to start motor in wash cycle.
You may have a damaged timer contact, due to the storms, but I would not make that the first thing to check.
You stated that you can drain(purge) the water indicating that the pump motor assembly is the least likeliest problem, at this point.
cmb78
#3 Posted : Monday, July 26, 2010 7:08:56 PM(UTC)
cmb78
The float and switch assembly is the round piece in the front, left, bottom of the tub??? I did raise and lower it and it did make a clicking noise. Any other things I can test to rule in or out the timer contact?
Joe / APP Team
#4 Posted : Tuesday, July 27, 2010 5:56:26 AM(UTC)
Joe / APP Team
Yes, the float is the round piece in the left front corner of the tub, and apparently working since you could hear the switch click.
Do you have a multi meter ?
At this point you will need to circuit check the float switch and fill valve solenoid circuits with a meter,and visually check the wires for damage, then consider the timer.
Make sure you shut off power to the dishwasher before you remove access panels, and start testing circuits.
Hope this helps you
