[FONT='Times New Roman']I have a GE Profile TFX25PRYD side by side Refrigerator/Freezer. There is a puddle of water from under the freezer side every so often. [/FONT] [FONT='Times New Roman'] [/FONT] [FONT='Times New Roman']Any help on what the cause can be? I moved the refrigerator and saw no leaks in the back or on the floor.[/FONT]
Originally Posted by: joec4571  I have a GE Profile TFX25PRYD side by side Refrigerator/Freezer. There is a puddle of water from under the freezer side every so often.
Any help on what the cause can be? I moved the refrigerator and saw no leaks in the back or on the floor. Checking the tubing and the coupling from the freezer door hinge to the fill valve for loose,dripping connections, would be the first(most likely) place to start. Especially for an intermittent water leak.
