Kathleen Lindsey
#1 Posted : Friday, July 23, 2010 4:08:38 PM(UTC)
Kathleen Lindsey
I just ordered a new detergent dispenser for my dishwasher from your company because the old one is broken. How should I go about installing it? I read someplace that the inside door panel needs to be removed. Once I get in there will it be obvious how to pull the old one out and install the new one? If not could you give me a little more information? Do I need to do anything about the timer?
#2 Posted : Friday, July 23, 2010 5:41:41 PM(UTC)
Kathleen,
It is very simple. Remove the inner door panel and the wires from the soap dispenser. Remove the screws secured the dispenser from inside the inner door panel and remove the dispenser.
Here are the breakdown diagrams and Replacement parts for General Electric PDW8880L00SS Dishwasher | AppliancePartsPros.com
