3 Pages<123
abbie
#21 Posted : Friday, June 13, 2008 5:38:25 PM(UTC)
abbie
If you happen to find the leak,and your able to repair it, change the drier and don,t leave the tap valve on your copper line,they have a chance of leaking after a while. Use a[saddle] valve that is soldered to the low side of the system....good luck
NoEcm
#22 Posted : Saturday, June 14, 2008 11:32:16 AM(UTC)
NoEcm
Here is an update:
I found a pinhole leak in one of the solder joints and repaired it (I hope that this was the only leak that I have but there is dye in the system in case there is another leak somewhere else).
Next, I replaced the dryer and added a solder-in access valve (as recommended).
Recharged the system and it is running at ~3 inHG and everything seems nice and chilly. It looks like I need to turn the thermostat up a little though.
UserPostedImage
I'll let it run a few days and see how everything works.
Thanks for all the assistance!!!
3 Pages<123
