If the thermostat for the oven was broken would the broiler still work? My oven won't work but the broiler does. Replaced ignitor for oven but it still does not go on. Yet the broiler does. Any suggestions?
Originally Posted by: butch194928  If the thermostat for the oven was broken would the broiler still work? My oven won't work but the broiler does. Replaced ignitor for oven but it still does not go on. Yet the broiler does. Any suggestions? Does'nt anyone answer these things??
It's hard to say exactly what is wrong without the wiring diagram for this particular model, which is not available on line. If you do have such diagram, post it here.
Originally Posted by: Gene  It's hard to say exactly what is wrong without the wiring diagram for this particular model, which is not available on line. If you do have such diagram, post it here.
Gene. Thank you Gene for getting back to me. Ignitor was broken right out of the box. Put in replacement today. works fine.
You are welcome. I'm glad to hear the problem solved.
