sdardoin
#1 Posted : 15 years ago
sdardoin
I have a Frigidaire side by side refrigerator, Model FRS6LF7JB0 that just made 2 years old. It has begun leaking water beneath the tray of the front ice/water dispenser. The water is running slowly down the front of the freezer door to the floor. I disconnected the water at the back of the refrigerator and the leaking has stopped.
I was able to find a schematic on this forum of the dispenser, but I cannot understand how to completely disassemble it and check to see if the water line is leaking inside.
Can someone please help me figure this out?
Also, is there a way to disconnect the water going to the door while still allowing water to go to the icemaker? I could live without the dispenser for a while, but i really need the icemaker.
Thanks in advance!
Here is my unit...
Ice & water dispenser replacement parts for FRIGIDAIRE FRS6LF7FB0 Frigidaire/refrigerator | AppliancePartsPros.com
#2 Posted : 15 years ago
Have you replaced the water filter recently?
sdardoin
#3 Posted : 15 years ago
sdardoin
Actually, no. We have great water where we are. Could it be clogged? Is there a way to check?
#4 Posted : 15 years ago
If you did not replace the water filter, then the problem more likely is a bad water inlet valve on the back of the refrigerator.
There is a water filter (#137 on the diagram) installed by the manufacturer. If this filter is more than a year old, most likely it is clogged. You can replace the water filter or install the bypass instead of the filter.
The instructions are in the Owner guideand/or on the filter pack.
- The water inlet valve Part number: AP4298908
- The water filter Part number: AP2538969
- The water filter bypass Part number: AP4499610
sdardoin
#5 Posted : 15 years ago
sdardoin
OK, this may sound strange, but I pulled the bottom tray off the dispenser. I didnt realize it was removeable. The water in the sump was almost overflowing. I cleaned it out and wiped everything down. I turned the water supply back on and in the past 24 hours it has not leaked.
This makes me wonder if the sump was just full because I had never emptied it? I honestly didnt know this needed to be done.
I appreciate the answers. I will continue to monitor it. I suppose it is a good idea to replace the filter? or should I just bypass it since I do not need it?
#6 Posted : 15 years ago
If you are sure you do not need the filter, just bypass it. You can buy the filter any time later.
