I need step by step instructions to replace a Lid Switch Whirlpool part# 3949247.
Remove the two control panel screws, tilt the panel back, remove the retaining clips that hold the outer panel to the base, remove lid switch connector and tilt and remove outer panel. Everything else is easy to replace the switch.
