Magic Chef oven not heating to set temperature. Both oven elements work. Can hear the control panel clicking to turn elements on but won't come to set point. If hold wet rag on temperature sensor inside of oven elements will stay on and oven will get hot. Is there a way to calibrate oven or some other suggestion.
I have the same problem with my magic chef, were you able to fix yours?:)
