3 Pages<123>
Biblee
#11 Posted : Thursday, June 12, 2008 7:00:32 AM(UTC)
Biblee
Thanks abadfish66 ! What does "ptc" stand for? Behind the cover on the compressor, I found a brown relay with 3 terminals (only 2 used and doesn't rattle) and separate from it (but right above it)there is a black and white smaller device with one terminal that rattles. Together they attatch to the pins on the compressor.
Do I replace both as a precaution or just the black and white component that rattles? Found slight discoloration around the 3 pins on the compressor these were attatched to. Maybe this was the target of the lightning? Hope compressor isn't shot. Even if this works I won't have the $$$ to put food in it for another week. Living on Ramen Noodles and peanut butter this week.
Apprieciate your thoughtfulness. Will ask the Lord to bless you generously for helping those in need.
Lee
abadfish66
#12 Posted : Thursday, June 12, 2008 7:22:57 AM(UTC)
abadfish66
Do you have a multi meter? Also PTC stands for positive temperature coefficiant (technical garbage)
Biblee
#13 Posted : Thursday, June 12, 2008 8:06:25 AM(UTC)
Biblee
Wished I had a Fluke but I do have a Radio Shack auto range digital multi meter. Can I use it to test components or compressor?
abadfish66
#14 Posted : Thursday, June 12, 2008 8:31:12 AM(UTC)
abadfish66
Yes you can. Take off the componets on the compressor and take ohms readings from the pins on compressor, the middle pin is your common terminal, so go from common to one of the other pins, write down reading, then from common to the other pin, and then measure the other 2 pins and post results
Biblee
#15 Posted : Thursday, June 12, 2008 12:36:22 PM(UTC)
Biblee
Common to left terminal 9.1 ohms. Common to right terminal 5.1 ohms. ???
abadfish66
#16 Posted : Thursday, June 12, 2008 12:46:04 PM(UTC)
abadfish66
now the right and left terminals reading?
abadfish66
#17 Posted : Thursday, June 12, 2008 1:00:02 PM(UTC)
abadfish66
Then check the white and black device, take reading between the gold and silver terminals
Biblee
#18 Posted : Thursday, June 12, 2008 10:37:21 PM(UTC)
Biblee
Yes. One terminal reading 9.1 ohms and the other reading 5.1 ohms. For what its worth tried across those two and got 14.2ohms.
Biblee
#19 Posted : Thursday, June 12, 2008 10:45:12 PM(UTC)
Biblee
Checked brown relay across terminals that go to the compressor pins. It reads 10.6 ohms. The smaller black and white device was checked from its single terminal to the single pin female end reads 0.3 ohms.Cou;d send digital picture of the devises and compressor if possible. I borrowed a friend's very small beer cooler (minus beer) for temp. I runs ALL the time and most likely use as much power as the big one.
Lee
I'm telling everyone about this great site !
abadfish66
#20 Posted : Thursday, June 12, 2008 11:08:40 PM(UTC)
abadfish66
Good news, your compressor is fine. I believe the problem is with your cold control (thermostat), or the timer. Can you hear the timer running? Try turning the timer dial around a few times, also get a piece of wire, and jumper the 2 wires that connect to the cold control, if it starts working after jumping the cold control, that is your problem, replace and enjoy.
Guest (12)
3 Pages<123>
