Lower heating element on upper oven does not work. I just replaced heating element. It still does not work. What is the next step? I have the back off and see no burns or disconnects.
shaun
Originally Posted by: sphsph  Lower heating element on upper oven does not work. I just replaced heating element. It still does not work. What is the next step? I have the back off and see no burns or disconnects.
shaun Does the lower oven work ? If so, suspect a damaged wire to the oven control assembly or a failed control.
