Ice cubes are all frosted together in basket we were told the seal is bad on the door ?
Originally Posted by: rothpr  Ice cubes are all frosted together in basket we were told the seal is bad on the door ? There are several possibilities, but yes in most cases air leaks at the door , air leak at the dispenser chute seal , door left open and similar situations, can and usually will cause ice cubes to stick together. There are other possibilities but at this point I dont think they would apply to your situation
