jooey2
#1 Posted : Monday, July 19, 2010 11:24:25 AM(UTC)
jooey2
Hi can you tell me how to get to the rollers on this dryer to see if I can clean them or if they have to be replace. Thank you I lifted the top and have no clue from there any help would be appreciated.:)
Joe / APP Team
#2 Posted : Monday, July 19, 2010 2:12:21 PM(UTC)
Joe / APP Team
Once you have the top up you will need to remove the front panel.this is accomplished by removing the 2 screws(1 on each side)approximately 5 inches down from the top of the panel on the inside, you will also need to remove the switch or wiring to the door switch assembly and the front panel can be lifted and removed from the cabinet.
After the front panel is removed you will need to remove the belt from the idler pulley and motor pulley and remove the drum, this is done at lower front right side of the cabinet interior.
with the drum removed you will have access to the rear rollers, idler pulley assembly and front glides.
Any component that wobbles excessively should be replaced. All components should be dismantled and cleaned and lubed with high speed machine lubricant and the slides with silicone based lube.
I have attached a parts diagram for reference and parts order if needed
Cylinder replacement parts for ADMIRAL ADG7000AWW Dryer - Gas | AppliancePartsPros.com
Squeeky dryer (Dryer Repair)
by lexusnip 8/24/2012 10:27:21 AM(UTC)
by julieshaver@bellsouth.net 8/13/2012 4:08:57 AM(UTC)
ear piercing squeeky dryer!!! Help! (Dryer Repair)
by fawn_eyes888 8/31/2010 12:10:36 PM(UTC)
Squeeky Dryer (Dryer Repair)
by tbela 8/21/2010 2:49:11 AM(UTC)
squeeky dryer (Dryer Repair)
by shorembo 8/20/2010 7:12:47 PM(UTC)
by Stonehenge 1/12/2010 4:11:33 PM(UTC)
by Squeeky Dryer 7/1/2009 4:21:34 PM(UTC)
by clayandlin 2/9/2009 9:19:18 AM(UTC)
