The right side door won't close completely. I have to push it by hand because the cam was broken. I ordered the part (lower hinge assembly) from Appliancepartspros.com and it arrived today. Unfortunately, I put in the new part and the door still won't close completely by itself. I have to push it in. Please help. Is there anything I need to adjust in order for it to work Thanks:confused::confused::confused:
did you replace the cam that is attached to the bottom of the door along with the hinge?
Yes, I replace the whole set, the cam and the hinge
Can you take a pic and post it...of the door and what you replaced
