Ice dispenser quit working. No sounds, motor turns freely, dispenses water ok. Nothing happens when push to dispense in either crush or cube. Suggestions? Thanks
To update my post, I removed the front plate via two screws under the drip tray, and the two little pins that hold the microswitch for the ice dispenser fell to the floor. They were broken off. New control bracket ordered. I pushed the switch and the ice dispenser started, so i found the problem.
